TwinTurbo.NET: Nissan 300ZX forum - Cylinder not firing, bad 02 sensor, burn exhaust valve
Subject Cylinder not firing, bad 02 sensor, burn exhaust valve
Posted by Audioquest on June 07, 2008 at 8:02 AM
  This message has been viewed 176 times.
In Reply To which are? (n/m) posted by aidemsined (to) on June 07, 2008 at 12:37 AM
Message How does it idle?
Start by running o2 diagnostics. Next pull CP plugs at idle and see if none make a difference. If you find one (or more) could be CAS or PTU plug corroded.
If none of those do a compression test
